waveform chart
In the below example when i enable plot visable it is enabling humidity values( yellow line) and when i disable it humidity values are not getting displayed.
In the same way i want to control temperature( Red line) also how is it possible
Message 1 of 9
(4,644 Views)
Accepted by topic author Nagaa
Hello 108
before setting the visibility you have to select the active plot. I altered your VI, so it could comes closer to your needs.
Btw., in LV2011 these Checkboxes are built-in.
Greets, Dave
Message 2 of 9
(4,641 Views)
i am using labview 2009 8.6 version could u change vi to that and send please
Message 3 of 9
(4,637 Views)
I got it now using active plot property thank you very much sir
Message 4 of 9
(4,634 Views)
Thzis is in Version 8.6.
Hope this helps,
Greets, Dave
Message 5 of 9
(4,632 Views)
thank you sir and one more question .
in my application of data logging . I have irregular values of time strings in the form of array is it possible to display my irregular time interval values in xaxis .
I tried but i am not able to get it.
see the below attachments
Message 6 of 9
(4,619 Views)
See the attached picture.
Greets, Dave
Message 7 of 9
(4,604 Views)
Through this we can get only regular intervals of time . but i want to display irregular intervals of time which i retrive data from the instrument
Message 8 of 9
(4,595 Views)
Hello 108,
this shows the way.
Greets, Dave
Message 9 of 9
(4,588 Views)
