wav into array??
hello im using labview 8.5 and i was wondering how to read data from a wav file and then write the data into 1D array?? thank you... i can actually read the file by using Soun_File_Read.vi , but i need a 1d array..
(5,264 Views)
You can use a reshape array .
(5,262 Views)
You can convert into an array as shown above. Is this what you are looking for?
(5,259 Views)
Use the index array to access the channel you want, then extract the Y array from that sound channel element. Pretty straight forward.
Paul
(5,257 Views)
thank you very much to all of you guys..  the reason i want to make that it's because i'm trying to use Fast Fourier Transform to that array... i already know there is VI (spectral measurements) but i want it more mmmmm to seem like the mathematic algorithm.. thank you
(5,253 Views)
