.wav file amplitude modulation
Hi!!! new user
please guide me i want to am demodulate a .wav file.and hear the sound.But the play waveform is not working properly giving error 4800.
I will be very thankful in this regard.
Message 1 of 12
(3,669 Views)
Hi umairpak,
Did you read the error explanation?
What kind of soundcard do you use?
Message 2 of 12
(3,662 Views)
Sir please observe the error.
Message 3 of 12
(3,629 Views)
Hi umairpak,
have you tried to get away without using ExpressVIs?
This works for me. (It might be technically incorrect regarding the waveform samplerate after decimation.)
Are you sure your soundcard can handle samplerates of 250kS/s (or fractions of it)?
Are you sure your DDT wire after decimation carries the correct samplerate? (Don't use DDT wires when you don't understand them!)
Message 4 of 12
(3,623 Views)
Sir I am unable to attach the .wav file i want to AM demodulate and hear the sound.
Your solution when I applied is i think still showing the same errors
and if the sampling rate is very high is creating issue then how to low it
Secondly i will be thankful to you if you give me some source to search for AM modulation of .wav files
Thank You!
Message 5 of 12
(3,593 Views)
Hi umairpak,
you can attach any file - once you pack it into a ZIP archive…
As you didn't answer my question I have to repeat it:
Message 6 of 12
(3,591 Views)
Sir i am attaching the sound files(.wav) which i have to AM demodulate along with my VI.And also i have attached a sound info. screen shot.
Kindly check where is the problem.Sir are there any drivers required in labview.Else if sound canont be played kindly guide me to save the AM demodulated waveform in a .wav file.
Message 7 of 12
(3,558 Views)
Hi umairpak,
As said before: my default laptop soundcard cannot handle your wav file using a samplerate of 250kHz. But after decimation and correcting the samplerate/soundinfo accordingly it accepts the waveform for playing…
Why should I? That is your own task/homework/job!
Message 8 of 12
(3,553 Views)
Hi umairpak,
Can you play any kind of wave file on your computer?
Have you tried any of those Windows sounds, just to check the PlaySound routines of LabVIEW?
Sometime the computer offers several soundcards (like internal Realtek and external USB-connected earphones), so you need to select the right device…
Message 9 of 12
(3,544 Views)
Any sound does not play on labview whereas every sound plays elsewise on my headphones
Message 10 of 12
(3,517 Views)
