wanted to build a vi to simulate press and hold button on a panel.
Had to simulate a press and hold button on a panel to activate the rest of the buttons on the panel.
So far, used Acquire input data, index array, case structure (boolean), all in a while loop.
Any comment to this approach or any idea appreciated,
The vi can be uploaded on request.
Rgds,
David
Message 1 of 16
(5,032 Views)
Not sure I understand. You want the button to stay pressed? Right click and change the mechanical action from latch to switch. Uploading the vi would be very helpful.
LabVIEW 2012
Message 2 of 16
(5,029 Views)
The button should act as a press and hold button on standard panels. A saftey feature which activate the rest of button on the panel provided that the button press and hold for certail seconds. Here is the vi.
David
Message 3 of 16
(4,998 Views)
I am still not clear with what you want...
Could you please elaborate on your application?
Prashant
Message 4 of 16
(4,987 Views)
Hi David,
I have attached a couple of vi's that might help. One is a press and hold vi, the other is an example of how it works.
Let me know if they help.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 5 of 16
(4,975 Views)
Hi David,
Couple of points wrong with my last 2 vi's, try these instead.
Rgs,
Lucither
Message 6 of 16
(4,971 Views)
Sorry,
Never attached the updated version, Try again Smiley Mad
Rgs,
Lucither
Message 7 of 16
(4,961 Views)
Hi David,
Just been thinking about the vi's i sent. Im not too sure (without testing which i cant be bothered to do) whether having the 'Initialise keyboard' and 'Close input device' inside the press and hold vi is a good idea, i am thinking that it is not (I'm sure that someone on here can confirm that for me). I have attached an alternative that i think will be better.
Rgs,
Lucither.
Message 8 of 16
(4,953 Views)
Thanks for files.
But could not open it is made by ver 9, Got version 8.5.1 and could not open it.
(sending in compatible format or sanpshots).
Message 9 of 16
(4,946 Views)
No worries,
Here they are in 8.5.
Rgs,
Lucither
Message 10 of 16
(4,944 Views)
