wanted info on how to use labview to get values from spectrum analyzer???
Hello Everyone,
 i am new member and i am doing one project that i have to see the performance of DSl cable(of differnt lenght eg 100m, 200 m) on spectrum analyzer and its values like graph, power, BW should be get in excel sheet. I have spectrum analyzer of Rohde and Schwarz company, i am using Agilent 82357B GPIB interface.... So anyone can help me how to start. I have connected GPIB to spectrum and its drivers on computer....
Thanks in advance
Pallavi
Message 1 of 10
(4,395 Views)
Hey,
If you are lucky, then there is an instrument driver available for the Rhode&Schwarz Analyzer which you can use in LabVIEW.
If not, then you will have to study the manual and programm every single command which needs to be sent to the Analyzer and to gather the data for LabVIEW....and this is a lot of work.
Christian
Message 2 of 10
(4,391 Views)
What spectrum analyzer do you use?
Message 3 of 10
(4,388 Views)
I am using Spectrum analyzer from rohde and schwarz FSP 9khz-3ghz 1164.4391.03. and i want to read values like power, BW directly to excel sheet...
Message 4 of 10
(4,381 Views)
@ christian can i get your mail id so i can mail u directly and discuss the things...
Thanks so much....
Pallavi
Message 5 of 10
(4,376 Views)
R&S is providing a "read trace example" which uses the RsSpecAn instrument driver (also in LabVIEW available). I recommend you to use this example as starting point for your development. Furthermore I recommend you to have a look into the R&S application note 1MA153. If you need further help, please contact the R&S customer support.
Message Edited by juergenstraub on 09-24-2009 11:17 AM
Message 6 of 10
(4,372 Views)
thanks a lot.... will try and let u know...
Pallavi
Message 7 of 10
(4,360 Views)
Hey Pallavi,
According to what Juergen wrote it seems that you where lucky Smiley Wink
I can only agree to what he wrote and suggest to follow his advice!
Christian
Message 8 of 10
(4,350 Views)
It's unforunate that you chose to use an Agilent GPIB controller instead of an NI one but you should be able to get that to work. at the very least, you need to enable tulip support. There may be some other things you need. Search the forum for references to the controller you are using.
Message 9 of 10
(4,301 Views)
Accepted by topic author Sim5
@Dennis Knutson
  i didnt chose it was given to me.... and i have to work using it only..... no option....
Message 10 of 10
(4,275 Views)
