want to create multiuser example
I want to create a application in which same vi will run on 3 or 4 computers connected on LAN.Its like a multiplayer game.
Is it possible? Are there any examples of such application. can someone give me such application to design.
Thank you
Gaurav KSmiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,528 Views)
Sure it's possible.  Are you looking for a game where each client has to connect and register with a master server, or one where all the players need to discover each other and communicate and an equal basis?  This would affect your architecture.
I've never done this myself.  But I would look through all the examples in LabVIEW under the Networking/ TCP and UDP sections to start getting ideas.
(2,520 Views)
thanks for reply. Yes i want to design same application, where in users will try to operate same vi,will try to operate a perticular variable...and i will have a combine effect of their action in vi.
Gaurav k
CLD Certified !!!!!
(2,517 Views)
