wait until next
i have little trouble with wait until next ms
the first loop is very large around expected cycle value so it generate desynchronisation on devices...
ex:  my cycle is 10 second and first loop can reach 6 second in worst case !!!
is there tips to have correct timed loops and avoid 1st loop trouble ?
i tried 2 solutions to bypass this probleme but i loose a full cycle ( 10 sec)
1) with 1st call function and a condition structure but it looks heavy "timer01.vi"
2) with a pretempo before real working loop, it seems to be correct on few trys but i would like to have confirmation about repetability "timer02.vi"
here two files attached with a simplified exemple for theorie , the light have to light on only 2 sec out of 4
cordialy
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,383 Views)
Maybe you should use a plain "wait(ms), instead of a "wait next ms multiple".
Better yet, use a timed loop. See attached.
Message Edited by altenbach on 04-03-2008 05:20 PM
(3,353 Views)
thank you altenbach,
i finally change to this structure, i tought  it was designed for  more  complex  applications,
now i  don't see when a wait until next can be usefull, or only if code takes 2 times less than loop cycle
Best regards
Tinnitus
(3,330 Views)
See here... there is nothing wrong about this function. You only need to know how it works ! Sometimes it is the way to go, sometimes other solutions may be better.
(3,324 Views)
For some other discussion about "wait next ms multiple", also have a look at the following thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=291455&query.id=41686#M291455
(3,290 Views)
