vsavvv
I'm actually a novice with programming on LabView, so I don't know the right methodology for my problem.
I'm working on a traction machine instrumented with a LVDT and a load cell which are analysed with a NI-USB 6008.
My problem is to do the acquisition and display the signals on a graph at the same time (a small time lag isn't a problem) and to keep the old plots on this graph.
So I would like to get :
- the evolution of the strenght depend on the LVDT
- acquisition and display at the same time
- save the old plots and values
Could you please exaplin me the way and the LabView tools to use ?
I thank you for your assistance which will be invaluable, I'm sure, very Je vous remercie d'avance pour votre aide qui me sera, j'en suis persuade, tres precieuse.
Joseph
(2,594 Views)
You are using a NI USB 6008 daq card.
  • first pick continous AI acq program for examples shipped with labVIEW.
  • To convert the voltage (that this program will read from the scanned channel) to LVDT displacement, you can use  custom scale VI function found on your tools palette.
  • next use a chart to dispaly data instead of graph. Because a chart has history memory and a finite number of past data samples can also be see on it.
  • You can use File I/O VI's to save data that you are acquiring.
Any doubts, do get back.
regards
Dev
(2,590 Views)
