vpn
hi..
Has anyone familiar with VPN?...Basically, not much I know about VPN. How to make the client can control and monitor the same vi that run in the server pc?..using TCP?...Pleasure if there is an code example or tutorial...thanks
(7,239 Views)
I think you may be confusing a couple things. VPN is a remote desktop application that lets you operate a computer like you were sitting in front of it. If you want to remotely control and call a VI all ou need to use is VI Server - and there are several good examples that ship with LV.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(7,236 Views)
hi mike,
yes, I know that VPN is a remote desktop application. I may be not really clear about VPN and VI server. I have an LV example that using the VPN. I noticed that I have to make 2 different vi which is server.vi and client.vi. In the example, it use read TCP and write TCP. I wonder how to make the server know which client is controlling the vi? Only one client can control at one time?..please assist me...correct me if i'm wrong..
(7,231 Views)
Ok, well there is another meaning for the acronymn "VPN". It can also stand for Virtual Private Network. In that sense a VPN is a network protocol that allows you to connect to a corporate network from the outside world. In terms of your question, because TCP requires a connection, the server inherently knows what computer the connection is coming from.
Mike...
LabVIEW Champion
(7,224 Views)
ok...if I have not setup the VPN, can I test my program without VPN setup?meaning that can I make a test familiar with the VPN application?I'm appreciate if u can give me an example code..thanks
(7,222 Views)
