03-17-2008 02:56 AM
Hi all,
As part of my work, I need to do some voltage measurement for a coin battery. I followed the instruction in the Getting Started with Labview, section Accquiring Data and Communicating with Physical Instruments, however the voltage obtain is very different from the voltage of the battery. As this is my very first time using Labview and the SC-2345, I just simply cannot figure out what the problem is. I hope you can help me with this.
Attached are the program and the set-up I use. I connect a battery to a resistor, and use the first set of cables from SC-2345 to connect to the circuit. The red cable is connected to the positive side of the battery and the blue cable to the negative side of the battery.
In Labview, I select physical channel ai1 to measure the voltage. For the Terminal Setting, as I am not sure what the difference is, I tried for all three available methods. However, the results are all wrong.
In fact, when I disconnect everything, the values are the same when being connected to the battery. My battery is 3V, whereas the reading is somewhere around 0.20V (if I use RSE) and around 5.2 (if I use Differential and set the max input as 5V). Apparently, the system isn't reading the value from the battery.
Do you know what could go wrong in the way I did? Is there anything that I need to set up but I didn’t? I checked the cables connections but all look fine to me.
Thank you very much for your help!
Best wishes,
Linh
03-17-2008 03:02 AM
03-18-2008 11:32 AM
03-18-2008 09:02 PM
Dear John,
Thanks a lot for your help. I'm using SC23435, PCI-6251 card and Labview 8.0.
(1). Here are how the cables connected:
- The cables are connected to SCC-AI01. This module is sitting at slot J1 (ACH0/8).
- The red cable is connected to Port 4, the black cable is connected to Port 3 of the module.
In using Measurement & Automation Explorer, the configuration of SCC is set as seen in the attached image “config.bmp”.
I did a simple test to measure only a battery of 3V using Test-Pannel, using different channel Dev1/ai0, Dev1/ai1, Dev1/ai8. However, the results are still wrong. Please refer to the corresponding images attached.
Do you know what else can go wrong? Thanks a lot.
(2). Actually, I need to do all this because I need to measure how long a battery last if it is used for running a constant current. I can't use the formula because in reality, the hours may be less than the capacity dividing the current. Hence, the engineer suggests me to use a resistor as a load to drain the voltage. When the voltage reaches its cut-off value, I can derive how long the battery run.
Theoretically, this is not true as well because when voltage is decreasing while resistor stays constant, current won't be a constant anymore. Nevertheless, I want to give it a try. Also, I am not sure if there is a better way to do this. If you have any suggestion, I would appreciate very much.
Best wishes,
Linh
03-19-2008 12:48 PM
