visa
Hy ya the code is working. Thanx a lot yar. But y havent u set the baud rate n al?
Message 11 of 21
(1,389 Views)
If you don't wire those inputs, the values used will be those inside the ()
E.g, the default baud rate is 9600.
So, the configuration values are (here)
I suggest that you unmark that first answer as a solution and mark the answer where Ranjeet_Singh attached the VIs. It may help someone in the future.
Regards.
Mondoni
Message 12 of 21
(1,384 Views)
I would like to add that Ranjeet_Singh's VIs are written as standalone VIs.  Normally you would only have one place where you configure your serial port and one place where you close it.
Bill
CLD
(Mid-Level minion.)
Message 13 of 21
(1,372 Views)
Bill,
Just checkin':
When you say "place", you mean the code?
Because that's what the way I've learned 🙂
Mondoni
Message 14 of 21
(1,370 Views)
@joaopam wrote:
Bill,
Just checkin':
You are correct.  Usually you have just one place in the code where you initialize the serial port.  And then one place (usually not in the same place as your init) where you close it.
The rare exception is if you expect something outside of LabVIEW to be using that COM port also.  But this is messy and it's better to avoid this if you can.
Bill
CLD
(Mid-Level minion.)
Message 15 of 21
(1,362 Views)
Yes, I agree with you.
The messy you've mentioned, I've experienced in my first months with LabVIEW. I don't have good memories with that. 😄
Thanks for the answer.
Regards
Mondoni
Message 16 of 21
(1,353 Views)
anyway.. Both the solutions helped me out !!Smiley Happy
Message 17 of 21
(1,338 Views)
Hi buddy,
                      Actually in all my application I am using 9600 as baud rate, 8 data bits, no parity and unfortunately labview uses this values as default values so Smiley Very HappySmiley Very HappySmiley Very Happy
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 18 of 21
(1,336 Views)
Friend billko,
                             I wrote this by taking into consideration that both the VI is running on 2 different PCs and will run only once i.e. if it either read or write the data from or to serial port then it will stop. As our friend is new in labview I tried to make it as simple as possible
And this is just a sample example and nothingSmiley Wink
--Ranjeet
Message 19 of 21
(1,333 Views)
@Ranjeet_Singh wrote:
Friend @billko,
And that is exactly how I interpreted it.  The first thing I mentioned was that I thought you wrote it as two separate standlone VIs.  I didn't want to make it sound wrong, I just wanted to make sure he knew your VIs were intended for a specific use.  🙂
Bill
CLD
(Mid-Level minion.)
Message 20 of 21
(1,323 Views)
