07-29-2011 12:22 PM
I don't have any NI hardwares. But i want to intreface temp sensor (some sensor) with labview. Is it possible with VISA. And please give me guidence.
Solved! Go to Solution.
07-29-2011 12:30 PM
VISA is used to pass messages between an application and some hardware that can be controlled by those messages. Unless your sensor has some means of communication (like a GPIB interface, Enet port, COM port etc....) VISA can't really talk to it.
07-30-2011 12:25 PM
sir,
Thank you..
Please tel me how to interface a sensor with labview without NI hardware.
07-30-2011 01:02 PM
You need to tell us what the sensor is and what type of interfaces it provides.
07-31-2011 03:21 AM
sorry.
serial port temperature sensor.
And
Can you provide VI which can comminicate with pendrive. like to see files in pendrive and format that pendrive .
07-31-2011 07:57 AM
If it's a serial port sensor then you'd communicate with it via the serial port. LabVIEW ships with a couple of serial port examples. Before you do that you should try to communicate with it outside of LabVIEW by using somethng like HyperTerminal if you're on Windows or some other free serial port terminal program. This will allow you to verify you have the right settings and the right cable.
As for the pendrive, your question is vague. When you plug in a pendrive it just shows up a drive in the operating system and you can access it using the file I/O functions. If you are trying to do raw USB communication, then you will need to get a lot more details from the manufacturer. If that is not what you meant then please describe exactly what you are trying to do.
07-31-2011 08:35 AM
Thanks a lot.....
