visa write problem
hello,
I am trying to control a Coherent Cube laser with labview 8.0 (RS232)
I always get the response 'invalid cmd' from the laser.
There is a software furnished by Coherent which works without any problem.
I monitored the datas sent by this software and labview through the serial port but I did not notice any difference.
Have you got an idea? (the baud rates is well configured)
Message 1 of 12
(4,900 Views)
This kind of problem is often a result of missing or changed termination characters. Does the laser documentation specify the syntax of the commands? Note that LV does not automatically append any termination characters, you must explicitly include them.
Lynn
Message 2 of 12
(4,892 Views)
Effectively, there is a termination character (carriage return=0xD) employed by the laser software and I added it on LV but it still does not work.
In fact the laser documentation specify the syntax of the commands but not the termination character, I saw it by monitoring the serial port when the laser software runs.
Message 3 of 12
(4,881 Views)
Could you post the code you've written and the manual for the instrument?
Message 4 of 12
(4,874 Views)
I post the .vi but I cannot find the user's manual in pdf.
baud : 19200
parity : none
data bits : 8
stop bits : 1
flow control : none
Syntax :
command=<value> (for instance : ?C returns the present operating current)
?<query> (for instance : L=0 set the laser off)
Message 5 of 12
(4,867 Views)
I don't see anything in the VI that would cause the write problem. Have you tried using Hyperterminal to communicate?
Message 6 of 12
(4,853 Views)
The VISA configure serial port.vi termination character defaults with the LF ( line feed ) termination character enabled.   That means your vi is transmitting a LF after the command you put together.  This may be causing your problem.
Message 7 of 12
(4,846 Views)
Scratch that last bit of babbling.   The termination character set by VISA serial config is only for the VISA read.  Has nothing to do with write.
Message 8 of 12
(4,839 Views)
So your query works but your command doesn't, is this correct?
(Query being the string which starts with ? eg "?S".      Command being "Command=<value>" eg CW=1)
If this is correct then you haven't got a problem with your Write because the Query has to seed the "?..." charaters before you can perform the Read.
Therefore the problem is on the exact syntax of the command string. There can't be any spaces between the command, the = and the <value> ie CW=1 not CW = 1.0.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
Message 9 of 12
(4,812 Views)
Yes, my query works but my command doesn't.
In fact I checked my syntax by monitoring  the information sent through the serial port.
I compared the syntax from the company's software (which works) and from my .vi (which does not work) and I did not notice any difference!!!!
I don't understand anything.
regards
hadrien
Message 10 of 12
(4,795 Views)
