visa usb out-in problem in labview and trying to understand it
hello i have developped a program on p18f4550 using flowcode v4 and i am trying to send 2 stings of length 20 to labview i am having problems setting up the interface on labview usb visa out and in and having problem getting to know the connections can i please get some help on how they work and how can i fix it?
(2,261 Views)
I saw your PH.vi and I realized several erros in that.
In your code there is a design pattern called State Machine. Your state machine could not stop if it has not been already stopped, the transition code-parts are wrong. About state machine you can read here: http://zone.ni.com/devzone/cda/tut/p/id/3024, http://zone.ni.com/devzone/cda/tut/p/id/7604 .
Here you can find an example for USB-RAW communication (with Event Handling): https://decibel.ni.com/content/docs/DOC-2022
Anyway, if you implemented the code in your microcontroller you should test it with a well-working program on the other side. Is you PIC uC side working well? Did you test it? If yes, you could build the LabVIEW program.
Peter
Peter Vago
(2,230 Views)
thank you:D thats appreciated i will check them and fix it
(2,219 Views)
