visa errors
When I try to use the IO Assistant Express VI ... I can configure and talk to my instrument just fine but when I try and run the VI I get thye following error.  Error - 1073807246 occured at Property Node (arg 1) in Untitled 1:Instance:0->Untitled 1 ... Possible reason(s): VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
I have tried everything I can think of with no success.  Anyone have any ideas?
Message 1 of 10
(4,826 Views)
Does some other program besides LabVIEW have the serial port open?
Message 2 of 10
(4,824 Views)
No there is no other device using the COM port.  I have also tried using hyperterminal to confirm the the device indeed works.
Message 3 of 10
(4,820 Views)
Accepted by topic author KTaschner
Did you close hyperterminal?  Or at least close the com port in hyperterminal?
I asked "is any other program using the com port".  I did not ask "is any other device using the com port."
Message 4 of 10
(4,817 Views)
I am also a Ravens fan.  No other program is utilizing the COM Port.
Message 5 of 10
(4,814 Views)
It's always good to hear from another Ravens fan.Smiley Happy
You marked the thread as solved.  Was that it?
If not, then search for the error number on the forums.  (Leave out the negative sign on the search.)  There are numerous other threads.  Usually the problem is some other program leaving the port open.  But there are occasionally other odd explanations.
Message 6 of 10
(4,812 Views)
No the problem HAS not been solved and I would appreciate your continued support.
Message 7 of 10
(4,810 Views)
Mr. Raven
It is LabVIEW not closing the COM port when it has finished running.  Do you know what I need to do close the port when it is finished?
Message 8 of 10
(4,804 Views)
Okay,  then go to my message that you marked as the solution.  Go to the options menu to the upper right and select "Unmark as solution".  If is it marked as solved, there may be some people who might skip over the thread who might otherwise help.
I don't have any other ideas.  Other than rebooting and try again.
Beyond that, sift the the message threads in http://forums.ni.com/t5/forums/searchpage/tab/message?location=Board%3A170&q=1073807246#message-list
Message 9 of 10
(4,802 Views)
How are you starting and stopping your vi ??
Try posting your vi sp we can take a look.
And it might by a good idea to shift to regular vi's.
These Express vi's are good to some level, but a some point you are better off.
Message 10 of 10
(4,794 Views)
