video input
i need to get video input ....avi or any other format...is there anyway else other than ivision to do this....
Regards
Message 1 of 15
(4,417 Views)
Please don't create separate threads for same kind of questions. Please wait patiently for some time. Somebody will surely help you in solving ur problem.
continue here
Mathan
Message 2 of 15
(4,416 Views)
Hi nolsgn,
As Mathan said please do not create duplicate threads.  However the quick answer to your question is yes.  The IMAQ driver can create, save, and manipulate AVI’s.  If you have a NI frame grabber then it should have come with this driver.  If not you can find it information about it at the following link.  NI Vision Aqusition
Adam H
Message 3 of 15
(4,390 Views)
sry..i m new at matlab....didnt get a single word u said..........
Regards
Message 4 of 15
(4,371 Views)
Hi nolsqn,
The software I was referring to are drivers and VI’s to use our framegrabbers within LabVIEW as well as others environments.  What National Instruments software and/or hardware are you using?  IMAQ dose not support the third party software you mentioned.  The advice I gave was assuming you were using LabVIEW or one of the other supported languages.
Adam H
Message 5 of 15
(4,352 Views)
well right now i m not using any hardware to aquire video ............... i was first trying to simulate the whole system to perform video streaming using ofdm...i dun know whether i should use any hardware and if yes which one????
Regards
Message 6 of 15
(4,337 Views)
Hi nolsqn,
You do not have to use any hardware if you are trying to input an AVI.  But what I need to know is what software you are using?  You have mentioned both Matlab and Ivision.  Neither of the products are National Instruments and we do not support them.  If you are having problems with them I suggest you contact them.  If you are having problems with National Instruments software I can help you with that but I need to know what it is.
Adam H
Message 7 of 15
(4,314 Views)
no i am using labview 8.2........... i was trying ivision to get avi input .....u said there is a way  to get avi input into labview......... i would like to know that.......thanx
Regards
Message 8 of 15
(4,288 Views)
There is a great search utility on this site. I'm not going to give you the links. It's better for you to learn how to use that. Type in the search box on top of this page AVI, and in the resulting page you get there is a list of categories. You could go through all 425 entries in the Discussion forum category of course but looking at the 9 entries in the examples category would be probably the most effective way.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 9 of 15
(4,280 Views)
Thank you for your response Rolf.
nolsqn,
There are also some AVI examples that get installed to LabVIEW's Example Finder (Help > Find Examples... > Search tab) Search for the keyword "AVI" and take a look at the example called Read AVI Example VI.
--Michelle
Message 10 of 15
(4,254 Views)
