viWrite vs. viWriteAsync
Quoting LabVIEW Online Reference:
"VISA Write
Writes data to the device. Whether the data is transferred synchronously
or asynchronously is platform-dependent. For Windows, add syncVisa=True
to the LabVIEW.ini file, which is located in the LabVIEW directory. For
Macintosh, add syncVisa:True to the LabVIEW Preferences file, which is
located in the System/Preferences folder. For UNIX, add
labview.syncVisa:True to the .labviewrc file, which is located in your
home directory."
IMNSHO, this is a very bad thing. The "default" is not a part of VISA.
It is LabVIEW behind the scenes choosing which of the two separate VISA
functions to call! Why?!?
If you develop a project using VISA Write, and then distribute it, it
will NOT run cor
rectly on another machine that "defaults" to
Asynchronous Writes. And vica-versa.
The VISA library has two separate functions: viWrite and viWriteAsync.
Why doesn't LabView just give us two functions?
Duh! VISA Write and VISA WriteAsync.
And by the way, the same applies to VISA Read and VISA ReadAsysnc.
So let's say you want to build an application for distribution. Your
user has to run your app's installation program, then run the VISA
runtime library and then dick around with the LabVIEW.ini file. Doesn't
seem like a "professional development system" to me.
Mike T
(5,016 Views)
Usually, when you distribute an application, you also distribute with it its
app.ini that is configured properly to the application needs. Thus in your
distributed application myapp.exe you add this line yourself in the
myapp.ini file and add the file as a support file installed in the
application directory.
I think asynch VISA is OK for GPIB on Windows (default) but not recommended
for serial I/O. This is why you have to add syncVisa=True when you use VISA
serial I/O.
Jean-Pierre Drolet
"Mike T" a écrit dans le message news:
3A32F01C.BE5B01E5@postoffice.pacbell.net...
> "VISA Write
> home directory."
> will NOT run correctly on another machine that "defaults" to
on. Your
> Mike T
(5,016 Views)
Thank you Jean-Pierre.
The only reference I found in LabVIEW docs was about LabVIEW.ini file.
Can you point me to reference info on myapp.ini?
I understand your point, and yes that seems like it would solve it for
distibuted apps, which was my example gripe :~)
However, what if I write an instrument driver? When I distribute the
VIs to other LabVIEW users, I must tell them to change their LabVIEW.ini
file?
I think you may know that VERY different programming is required for
sync versus async calls. The async functions return immediately, so you
can do other processing while the I/O completes. However, you MUST
determine that the I/O did complete before you attempt more I/O with the
same device. And GPIB devices typically tens of milliseconds to
complete I/O. In my opinion, the vast majority of GPIB applications
don't have any other processing to do while waiting for the last I/O to
complete. So sync I/O ought to be the default because it is much
simpler and straight forward. You call the function, the I/O completes,
and the function returns. Good, clean, data flow programming :~)
Even still, I just do not understand why LabVIEW does not provide both
VISA write functions (sync/async) and both VISA read functions. Is it
not conceivable that a single application would want to use sync I/O in
some cases and async I/O in others?
Thanks again for your thoughts.
Mike
> serial I/O.
> Jean-Pierre Drolet
> "Mike T" a �crit dans le message news:
> > "VISA Write
> > home directory."
> > Mike T
Mike T
(5,016 Views)
Mike:
This has been addressed in LabVIEW 6i by removing the option from the INI file. You now select synchronous or asynchronous behavior by right-clicking and selecting the mode. The default, if I recall correctly, is asynchronous. But new VI's will no longer depend on the target machine settings.
Dan Mondrik
Senior Software Engineer, VISA
(5,016 Views)
