viWaitOnEvent timeout??
I have a simple application (LV2009, VISA 4.6.2) to communicate with equipments using a GPIB-USB-HS.
When runned in the development environment no error is generated but in the exe I can see in spy a lot of viWaitOnEvent timeout error. In the attached spy files I perform the same task in the development environment and in the executable.
1- start application
2- set the VISA Ressource Name control
3- send the *IDN? command using VISA Write.
Note that the errors appears only in spy, no error is reported by the exe (I receive a correct ID query response). I can also see that in the the development environment the function viWrite and viRead are used and that the exe use viWriteAsync and viReadAsync, why??
Ben64
(3,897 Views)
Accepted by topic author ben64
OK I found the answer in this old 2001 thread: viWrite vs. viWriteAsync
http://forums.ni.com/t5/LabVIEW/viWrite-vs-viWriteAsync/m-p/8873/thread-id/6999
You can right-click the VISA Write and VISA Read functions and select the Synchronous IO Mode -> synchronous. This removed the viWaitOnEvent timeout errors and now the viWrite and viRead are used in the exe.
I still wonder why in the development environment the viWrite function is used and in the exe the viWriteAsync functio was used. Maybe because of the OS (WinXP Professional v5.1) seiing a serial IO because the USB-GPIB-HS is connected to a USB port?
Ben64
(3,880 Views)
