vi server in application builder
I would like build my application.
the application have field point dual channel and the vi which control the banc is called and controlled by VI SERVER.
Is need to charge in application.bld the dinamic vi?
Thank's for answer
Bytelabs.it
(2,751 Views)
Nicola,
Here are some documents that explain how to use the VI server with your executables.
Hope those would be enough to answer your question.
Using VI Server to Pass Data between a VI and a LabVIEW Executable
Can I Launch a VI Within an Executable Dynamically Using VI Server?
Frequently Asked Questions (FAQs) on the VI Server
The attached example includes an executable that was created from a LabVIEW VI using the App
lication Builder. Once this executable is running, a second LabVIEW VI can read the value of the numeric indicators in the running executable using VI Server. The VI used to create the executable is included in the .zip file. Additional instructions on how to get the example to run correctly are included in the readme.txt file and the documentation of the second VI.
Zvezdana S.
(2,751 Views)
