vi server - Error 1000
Good Morning All,
I have two simple VIs thats basically running timer with nothing else (Vis are called Left and Right). I am trying to learn and understand VI server capabilities. Eventually I will have 3 VIs running (Main calling two sub VIs Left and Right). Each VIs (Main to Left and Right, Left to right, and Right to Left) will have Data, Controls and Indicators passed to and from each other. Codes sample images below. When running Main that calls Left and Right I'm getting error 1000. I have read most blogs related to VI servers on this forum but could not fix the prob. Any help is appreciated.
(5,236 Views)
Since you didn't provide your code, I can only guess.  Notice in the detailed description of the Run VI method, it says "You cannot use this method to run a VI that is already reserved for execution by another VI."  Probably you are referencing the subVIs somewhere in the main VI; and that causes them to be reserved for execution.
(5,221 Views)
Are the two VIs (left and right) the same? If so you could have one VI that served both functions, but with different input parameters.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,215 Views)
Thank you for your prompt response. Attached is the code. I am only calling the VI from Main for the first time.
I saw your second post about two VIs doing the same thing. Currently I'm only trying to get it running in parallel. It will have different functions in the end. Since I'm new to this I may have missed a file in zip. Let me know. Thanks for all your help!!
Br,
Ken
(5,211 Views)
Running VIs in parallel is basically pretty easy. The link in my signature is to my blog and I have written a lot about how to implement parallelism.
Mike...
LabVIEW Champion
(5,200 Views)
Mike,
Thank you, I've just registered on your blog and I will go thru it.
Br,
Ken
(5,195 Views)
MIke,
I looked at your blog and still clueless.
Please see my code .zip attached in previous posts.
Br,
Ken
(5,157 Views)
