vi program
Hello Everyone,
 I work with program ask to find Open program on deskbar.vi
but I could not find it, how can I creat this vi or replace it with another?
Sameera
Message 1 of 14
(5,306 Views)
Many people on this forum will not open a docx file. Create a screenshot or attach the VI.
LabVIEW 2012
Message 2 of 14
(5,298 Views)
Message 3 of 14
(5,275 Views)
Post the vi you are trying to open I guess that may be calling a sub vi created and saved in a desktop when it was coded originally. Ignore the vi while loading and see where that vi is used.
Message 4 of 14
(5,270 Views)
Hi Sameera,
your VI is searching for a subVi but can't find it.
- When the VI comes from an NI example it should know how to find the subVI (unless you're missing some toolkits).
- When the VI comes from the forum you should ask the one who posted the VI for all needed subVIs.
Message 5 of 14
(5,269 Views)
I attached the VI.
Message 6 of 14
(5,264 Views)
Unless you know exactly what the subVI is supposed to do, you cannot recreate it. Replacing it with some other random VI would also not make sense.
You need to contact whoever gave you this code.  From the looks of it, there are many other parts missing.
Alternatively, you can use the existing code and try to eliminate the missing subVIs, eliminating certain non-essential features in the process.
Message 7 of 14
(5,259 Views)
Only this part it is very necessary.
Message 8 of 14
(5,254 Views)
Hello sameera,
                     Make a sub VI that works accordingly and place that VI in the vaccant position and make necessary connections.
              danil33
Thanks as kudos only:)
Message 9 of 14
(5,228 Views)
I would recommend you to go to the place/person from where you got the code and get that sub vi. Its makes no sense to create a vi to which you do not know the operation of that vi.
Message 10 of 14
(5,221 Views)
