.vi loader points to the .NET assembly, but cannot find it
Using LV12 for this:
I have made a program that uses SharpSvn to store and retrieve our testprograms from SVN.
When running in development, there are no issues. (in the folder that I have my project, the SharpSvn .dlls are placed in a folder called "SharpSvn")
Then I build the application and select that the folder SharpSvn should always be included. Under "Source File Settings", I have set SharpSvn for "Support Directory" (the data folder).
The .dlls are all correctly placed in the folder data.
Then I copy the application folder to a shared network drive and try to run the application.
When I launch the application I get the ".vi finder" pop-up looking for "SharpSvn.dll ", BUT, it says loading "Y:\_Temp\pajen\Vaseline\data\SharpSvn.dll" and looks in a different place... when that is the actual address for the .dll (see images below)
If i copy the .dlls to the topfolder, everything works like a charm... What am I missing / doing wrong? Smiley Frustrated
(2,479 Views)
I look foreward to see a solution on this problem because I have the same problem!
Thanks in advance
Bjarne
(2,439 Views)
