.vi file crashes as soon as it starts running
Hello, a .vi file crashes when I click the Run button. What can I do to fix this?
Message 1 of 8
(2,253 Views)
It would help to attach the vi.
It could be corrupt, try making a new vi, and simply copy the block diagram of the old vi into the new one.
Message 2 of 8
(2,248 Views)
1. Post the VI so we can help you fix it.
2. Explain what you mean by "crashes"
3. Read here.
Certified LabVIEW Architect
Message 3 of 8
(2,247 Views)
Correct the part that makes it crash
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 8
(2,226 Views)
Here's the .vi file in question. I'm suspecting that it was corrupted, but I can't confirm.
Message 5 of 8
(2,196 Views)
Also, by "crashing", I mean that the software closes immediately after clicking "Run".
Message 6 of 8
(2,194 Views)
Here's the .vi file in question. I suspect that it's already corrupted, or, some of the subVI's are corrupted, but, I can't tell for sure.
Message 7 of 8
(2,189 Views)
Hi user,
The VI is missing several subVIs, so we cannot run it…
What happens when you start it in step-by-step debugging mode?
Message 8 of 8
(2,184 Views)
