vi Call by reference subpanel update value connector pane problem
I do not understand what you are asking. Can you give me a more detailed question?
R: Yes of course, thanks.
What are your objectives?
R: My objective is to open the subvi initconfiguration in subpanel (this subvi will remain in a loopwhile or in manage event case) until i'll press the button "update".
At this subvi i pass an input cluster (for example the init configuration parameters read from an external file) and  i want update this cluster in the main when i'll exit from the subvi Initconfiguration (pressing "Update")
What do you need this thing to do?
R: This is for using a data intialized in main and pass this data to subvi to change this data. I have to use a subpanel because my application is complex (i need to test a software functional block stimulate input and monitoring out) and i have to make some different configuration interface (for rs232, for analog input, for analog output )
What is this going to interact with?
R:It interact with a proprietary device that communicate with rs232 interface
How are you using this vi to provide data or serial configuration to other parts of you code?
R:I'm using queue to send the configuration cluster to the rs232 thread
I do not have the big picture so I am not sure how you plan to use the information in this vi.
R:The main objective problem is:
-open this subvi in a subpanel
-pass a cluster to this subvi in input and recevive this cluster modified in output
-i need this subvi made with a while loop or event case to modify the configuration parameters and i would remain into this subvi until i'll press the buttom update
-the problem is that i couldn't execute insert into subpanel until it will exit. I try to parallel "open by reference" and "insert into in subpanel" , but the subvi won't   appear into the subpanel.
If i'm not clear enough, please ask me more details again
Your sincerely Michele
Message 21 of 22
(484 Views)
Hi Tim, have you already seen my answer? Your sincerely Michele
Message 22 of 22
(466 Views)
