06-07-2016 03:39 AM
I got simulation and a value is so small, i.e 50nV (10^-9) or something like that, but only what I see is only 0.00 and that the only positive or negative sign is chaning in time, but the value is not changing. How to see very small value? What is wrong?
Thank for help
Solved! Go to Solution.
06-07-2016 03:41 AM
06-07-2016 03:43 AM
Which numberi indicator? Can you explain correctly. Where I can find it.
06-07-2016 03:52 AM - edited 06-07-2016 03:53 AM
Hi Jack,
Where do you "see" this value of 0.00?
Probably in a numeric indicator!
Change the formatting of this indicator to suit your needs!
I used the "official" LabVIEW wording of "numeric indicator". You can lookup this in the LabVIEW help!
And I think I explained the solution "correctly"…
General recommendation:
When you have LabVIEW specific questions it always helps to attach a VI (or snippet) to explain the problem you have. We will quickly answer, most probably with a VI showing the solution to your question!
06-07-2016 03:53 AM
I get. Thanks
06-07-2016 03:54 AM
Yes, the value is in numeric indicator, but klicked right-mouse and I got.
06-07-2016 12:59 PM
I guess you could've just resized the control until you can see enough zeros?
