vertical scrollbar when you start program
hello,
where do I set up when the program starts to show a vertical scrollbar?
front panel is higher than the monitor and I do not see the whole FP.
Peter
(3,004 Views)
Go to vi properties, window appearance, customize, show vertical/horizontal toolbars.
Select the appropriate boxes... and voila!
(2,996 Views)
Use Maximize property, it will fit your FP according to screen resolution.
Use Vertcal scrollbar property, set it to true or else go into VI properties>> Window appearance and select "Show vertical scrollbar"
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,995 Views)
thanks ....I am about blindSmiley Indifferent
(2,990 Views)
