vc++ dll with multiple data types
rolfk wrote:
smercurio_fc wrote:
The Reshape Array function is first used to make sure you have an array that's the same size as the fixed-size array in the target structure. Thus, in your case both arrays would be "reshaped" to 3 since that's the size as defined in the structure. This is then converted to a cluster. This is the "repackaging" part.
Haven't looked at the code but I don't think reshape Array is necessary. The Array To Cluster node has a right click popup dialog that defines the element size of the clusterindependant of the actual size of the incoming array.
I was explaining what the example was doing as I wasn't sure if the OP understood what the example was doing. Good point about being able to eliminate the Reshape Array. Not sure why the creator of the example used that. It's an old example, so perhaps the functions operated differently a long time ago? Can't really see how, though. In fact, looking at the example in more detail, it can be simplified for the string part as well.
To ghatz85: I forgot to mention in my explanation that you need to set the cluster size. The example has the cluster size set to 50 since that's how many elements were in the array. The string in that example has 51 (50 characters + null). So for that the Array to Cluster is configured for 51 elemetns.  As I pointed out, the maximum that you can set is 256.
EDIT: Saw the post that you did that. The setting of the cluster size is absolutely necessary, but I hadn't made that crystal clear.
Message Edited by smercurio_fc on 01-29-2010 11:01 AM
Message 21 of 27
(1,952 Views)
If I have an 2D array which includes more than 256 elements, what would i need to use instead of the array to cluster?
Message 22 of 27
(1,918 Views)
You need to write in C a wrapper function that translates the LabVIEW array handle into a C array pointer.
Message Edited by rolfk on 02-03-2010 01:04 AM
Rolf Kalbermatter  My Blog
Message 23 of 27
(1,908 Views)
extern "C" _declspec(dllexport) int _cdecl AOS_GetData_Array_GH(void *testArray);
typedef struct
  double T1[2];
 } Test_array;
struct MainTestArray
 Test_array pTest_array;
 maintestArray = (MainTestArray *) testArray;
 maintestArray->pTest_array.T1[0] = 1.11;
 maintestArray->pTest_array.T1[1] = 1.22;
 return 1;
If my DLL was as simple as this, how would the wrapper DLL look?
Message 24 of 27
(1,877 Views)
typedef struct
  double T1[2];
 } Test_array;
First your example is syntactically not right! You pass in a void pointer and assign it to an untyped variable. That variable should at least be declared with a type (on the local stack) and since you simply assign it it would be much better to type the parameter itself instead of making it a void pointer and then assign it to an according pointer.
And with above in mind there is no wrapper DLL necessary since above declaration is most likely different to what you intended. What you have done could be done much simpler with:
typedef struct
  double T1[2];
 } Test_array;
extern "C" _declspec(dllexport) int _cdecl AOS_GetData_Array_GH(Test_array *testArray);
 testArray->T1[0] = 1.11;
 testArray->T1[1] = 1.22;
 return 1;
For this no wrapper DLL is necessary since you can simply create a cluster in LabVIEW containing two double precision numbers, configure the parameter as Adapt to Type and connect that cluster to it et voila.
Message Edited by rolfk on 02-04-2010 08:27 PM
Message 25 of 27
(1,872 Views)
typedef struct
  double T1[300];
 } Test_array;
 testArray->T1[299] = 10;
 return 1;
So then what if the code looked something like this with 300 elements as opposed to only 2. Then i would need a wrapper DLL like you mentioned before. The problem here is that my programming skills are pretty much minimal to non existent. Now, going back to my previous question, what would the dll look like if it was written for vc++?
Message 26 of 27
(1,860 Views)
ghatz85 wrote:
typedef struct
  double T1[300];
 } Test_array;
 return 1;
Personally I think someone who has written such a function should probably be put into a different job where he does not get a chance to write more software, but that is simply my own opinion.
Still there wouldn't be any wrapper needed for this academic case. You simply allocate a 300 element double array in LabVIEW and pass it as a C array pointer to the DLL function. Even if the fixed array wouldn't be the only element in the cluster you could still allocate a byte array that is long enough to represent all elements in the cluster pass it as C array pointer to the DLL and on return convert the byte array back into a real LabVIEW cluster by indexing into the correct offset of the byte array and Unflatten the different elements to the actual value or even a double array.
Message 27 of 27
(1,851 Views)
