variant type conversion to boolean
@ThiCop wrote:
Thank you for elaborating on this with relation to integers so that they will always try to wire the type input.
Then where's my Kudos?Smiley Wink
Message 11 of 31
(3,794 Views)
My Kudos-wallet has been recharged and the deserving have been rewarded 🙂
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 12 of 31
(3,779 Views)
When I want to create a constant to that input (right click, create) an empty square appears and then I could not find any way to put a value in there !
I read accross the help file and didn't find any explanation how to do this either !
Thanks for your help.
Message 13 of 31
(3,774 Views)
Hello pgo,
You probably read over a part of my post consisting out of 2 parts:
1)  "create a new true constant from the function palette ..." (this is not right click create)
2) "... and wire it to your type input (so that you are not depending  on any autoresolving things)?"
Kind Regards,
Message 14 of 31
(3,770 Views)
And the same can be done for a numeric constant.
Just grab/take it from your Function Palette.
The function palette can be accessed as shown in attachment.
And if you don't find it, then use
either the search bar of the Function palette (search for "numeric constant" or "true constant")
or the Quick search (CTRL+spacebar)
Kind Regards,
Message 15 of 31
(3,768 Views)
Ok, Sorry.
I just did it but get the same error: incompatible data
Message 16 of 31
(3,764 Views)
This seems to work.
How do we trigger that Kudo thing? 😉
Best regards.
Message 17 of 31
(3,757 Views)
This seems to work.
Best regards.
Message 18 of 31
(3,756 Views)
Hello pgo1,
Below the name of another user you can click on the symbol I indicated in attachment.
You cannot give Kudos to yourself... 😉
Kind Regards,
Message 19 of 31
(3,750 Views)
You really should also mark this post as the soltion since it is the one that got you there:http://forums.ni.com/t5/LabVIEW/variant-type-conversion-to-boolean/m-p/2376482#M738961
The person who started a thread can mark any post in the thread as the solution.  Just go to the message.  There's an options drop down on the right and select "Mark as Solution" (or something along those lines).  Glad to see you got it working.
Message 20 of 31
(3,739 Views)
