value comparison for specific time
This should meet your requirements.  I chose the limits and target time sort of at random.
Message 11 of 19
(1,643 Views)
.I made a version too.Will it keep on updating ? cause i am selecting an element from a 1d array and comparing it and at 51.2khz.My version works real time but the button has to be in the loop.Would it update  or take new values if i use in range and input values from outside the loop ? since i cannot auto index do i have to put the 1d array in the loop itself and extract the element to compare?
I really appreciate your help.
Message 12 of 19
(1,633 Views)
Below is the vi that i am working on.
Message 13 of 19
(1,628 Views)
Did you really do an Equals to False?  Want to end up in the Rube Goldberg Thread?  Just use a NOT.  And none your case structures are needed, as I have already shown.
You will need a seperate timer for each comparison you want to do.  And these comparisons will need to be in your main loop that you are getting the data.  You have not shown enough context in order to give a better answer.
Message 14 of 19
(1,609 Views)
LOL.sorry about that.Still a newbie.Any ways i have attach the first half of my vi.
Message 15 of 19
(1,603 Views)
Ok, so you are just finding the peak of your FFT and doing a comparison on that.
1. No need for the Index Array.  You already have that value with the Max & Min.
2. I would turn the VI I gave you into a reentrant VI.  You can then call this VI in parallel as many times as you need and each comparison will have its own timer.  It will make your life a lot easier.
Message 16 of 19
(1,583 Views)
Thanks.Thats a new concept to me.So if i use 4 clones of that vi how can i enforce four different comparision ranges/values?
Message 17 of 19
(1,577 Views)
Excues my ignorance,I am looking at examples now.Thanks a lot for your help.Will try this tonight!!!
Message 18 of 19
(1,573 Views)
It works like a charm.Thanks a lot Crossrulz!!
Message 19 of 19
(1,527 Views)
