validating input value
(3,829 Views)
Hi All ,
I have an input parameter that i want to check its value when i press some button.
if the value is not as i expect than i want to prompt the user for invalid input values.
This all happen in event-case loop (if it has any affect on your answer ..)
how do i do it ?
(3,828 Views)
Hi
Use the producer/consumer-pattern. Using the event-structure you can feed a queue with elements, which are dequeued in a second loop, which contains a case-structure. So if you detect invalid data, you just can enqueue new appropriate elements.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,825 Views)
Hi ,
The only thing that interest me is how to prompt the user with that warning .
can you focus on that ?
(3,822 Views)
Attached you find an very simple example, how I would do it. Of course the vi itself could be coded better, but just to give you an idea.
Using LV8.0
(3,819 Views)
Hi ,
Got what i needed ,
(3,815 Views)
