using waveform graph
Hello!
I'm using the waveform graph to plot a real vector.
What I have to do to plot it with bars?
Can I do multiplot with this block?
Thanks!
(2,999 Views)
Right click on the plot legend and select Bar Plots. Pick the style you want. If you wire a 2D or a waveform array to a graph each array will be plotted separately. Expand the plot legend to control the number of plots visible and to select the properties of each one. Open the shipping example called Waveform Graph.
(2,991 Views)
