using values from list or dropdown-menue
Hello
I need a VI in which i can choose from different entries from a dropdown-menue. for every entry there are linked values (about 4). this values then i need for some calculations. So, the calculatons are done in dependency from what i have choosen in the dropdown menue.
The user should be able to add and delete entris to the list in runtime-modus.
can somebody help me?
thank you very much
Simon
Using Labview 7.1
(3,103 Views)
I made a small example. When you choose a entry in the drop-down field, the accoridng values are displayed in the numeric controls. To add a new entry in the dropdown list, first choose your values, then click into the dropdown list and enter a name for the entry you want to have. After that the entry is inside the drop-down list, and the according values are stored in the array of clusters.
Hope this helps!
André
(3,076 Views)
Sorry, I'm unable to open the file because i have LV 7.1
can post it as 7.1?
Thank you!
Using Labview 7.1
(3,060 Views)
Here you go.
Next time when you post a message, please tell us which version of Software you are using. That would make it easier.
Thanks.
(3,044 Views)
