using typecasting function
hello,
I am trying to convert a binary string to a double precision floating number using typecasting function ..How do I set the type of the data required..Is this a constant,indicator or control..?
-innovator81
(2,963 Views)
Connect the type of data you want to cast to (U32, I16, ect) to the center terminal on the type cast function.  See the attached VI.
More commonly, I use the Unflatten From String function, it is more powerful.  I rarely use typecast.  You must also not the endian type, typecast assumes big-endian, Unflatten From String lets you choose.
More questions?
Chris
Chris Reyerson
Optical Systems Engineer
Arete Associates
Tucson, AZ
(2,953 Views)
It is irrlelevant what you connect to the typecast function, it just needs to be of the desired data type: DBL in this case. The value itself is not used. Most often, I use a diagram constant, but you could also use a control if one is there anyway. (An indicator won't work, it needs to be a data source, not a data sink.)
(2,946 Views)
hello,
Yes I have used a constant(a double precision float for the type ) which converts my binary string to double format..it is working fine..thanx
-innovator81
(2,926 Views)
