using template for constrained LM fit
Hi
I am trying to do a constrained Levenberg Marquardt  fit. How can I set up the function by using the template ? I attach here the regular LM fit I have, with some (poor) data.
thanks for help ( I read the help file but it is not too clear to me...)
regards
(3,263 Views)
Hello nitad54448,
Thanks for posting on National Instruments Forum.
You can find on the links above some information about the Levenberg-Marquardt functions in LabVIEW.
Introduction to Curve Fitting
What is the Difference between the two Levenberg-Marquadt VIs in LabVIEW
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,238 Views)
bonjour
merci pour la réponse .. le problème est comment définir la fonction dans template.. je vais y arriver un jour 🙂 !
cordialement
N
(3,224 Views)
See if this post and example helps you.  It shows you how to set up the reference to the f(x,a) subVI and use it to call the LM function.  No constraints but it should help you out.
http://forums.ni.com/ni/board/message?board.id=170&message.id=448715#M448715
(3,177 Views)
