using slider for tcp ip
i am using labview to create a tcp ip connection.. in my client i am using a slider, and i want the slider on my server side moving along with the slider on client side.. currently i am stuck in case structure for the slider on server side.. can some one solve it for me??
(3,058 Views)
Hello Mahe something that really can help you create this behavior is using shared variables and Front Panel Binding.  you just need to bind both sliders to the same variable, and if you move one the other will update, this makes a lot easier to achieve this.
Controlling a Front Panel Control Remotely Using Data Binding - LabVIEW Help
https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html
Reading and Writing Front Panel Data Using Data Binding - LabVIEW Help
Binding Front Panel Controls to Shared Variables - LabVIEW Help
https://forums.ni.com/t5/Discusiones-sobre-Productos-NI/C%C3%B3mo-Configurar-multihilos-in-LabVIEW/m...
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(3,056 Views)
wow... thanks man!! really appreciate it.. now it works like heaven.. ^^ thnks
(3,048 Views)
