using scan from string
Hi
I am reading a string from an instrument in the format hr:min:sec, 0.000, 0.000, 0.000,0.000
I need to separate each part and add it to an excel file. I have triend scan from string and
string subset. I am unable to use scan from string as the first output is in different format than the others.
I cannot use string subset as the value changes to a negitive value sometimes which makes it difficult to get the right string lenght.
Can someone help me in figuring out the best way to split the string and add to an excel file
Thank you in advance
Raghu
Message 1 of 20
(4,539 Views)
Do you have an actual string that you can attach?
Tim
GHSP
Message 2 of 20
(4,536 Views)
I am reading it from Visa read buffer
Message 3 of 20
(4,531 Views)
Can you read one into a string and save it ina control or indicator, Text file etc... ?
Tim
GHSP
Message 4 of 20
(4,529 Views)
Yes. I can read and save as an indicator
Message 5 of 20
(4,516 Views)
Save it as an indicator with the default value and post it here and I will see what I can do for you.
Tim
GHSP
Message 6 of 20
(4,510 Views)
Well, then why don't you do so?
Or, run the VI and get a screenshot of the result. Post it. Note: DO NOT UPLOAD BITMAPS, AND DO NOT RENAME BITMAPS TO TRY TO GET AROUND THE BAN ON BITMAPS.
Message 7 of 20
(4,509 Views)
I could not paste the screen shot.
Here is the indicator value
12:02:07, 0.002, -.---, -.---, -.---,
in  the mean while i am trying to upload screen shot.
Thank you
Message 8 of 20
(4,493 Views)
As much fun as it is to parse strings, Excel is perfectly happy reading comma separated values, and simply appending those strings to a text file should work.  Name it 'whatever.csv' and you should be good to go.
Message 9 of 20
(4,498 Views)
Here is the screen shot after I ran the vi. Along with copying the data to an excel sheet I need the individual data to use in my program later.That is the reason I wanted to parse the string.
Raghu
Message 10 of 20
(4,463 Views)
