using /qb! option for silent install/uninstall of LabVIEW application
Hello all,
I am trying to use "/qb!" option for installing and uninstalling LabVIEW runtime engine silently with basic UI (need to hide the Cancel button). But the cancel button still appears on the screen. Is there any reason why this doesn't work? any input will be appreciated.
LabVIEW version: 2011 SP1
Operating system: Windows XP
I wrote a small LabVIEW program and with SystemExec.vi to run the following command:
C:\Program Files\National Instruments\Shared\NIUninstaller\uninst.exe /qb! /x "NI LabVIEW Run-Time Engine 2011 SP1"
I still see the cancel button on the basic UI.
Thanks!
(2,987 Views)
Hello
What happen if you use the same command from the windows command line in your computer? Is the issue around the SystemExec.vi...?
(2,960 Views)
When I tried to run the run the command from the DOS prompt I get the same result (with the cancel button present).
(2,949 Views)
what about other installer (different from NI)? it is necessary to isolate the issue, between windows and the LabVIEW run time engine installer.
(2,934 Views)
