using posttriger mode
i am using hardware trigger.
what i want to do is to wait some time after the trigger and only then
start taking points.
how can i do this?
thanks.
david
(2,797 Views)
If you look through the DAQ examples that ship with LabVIEW, you will find an example of exactly this.
Look through the code, and you should be able to figure it out pretty easily. Also, you may be able to just use the sample.
(2,797 Views)
AI Trigger Config.vi has a setting for delay.
(2,797 Views)
