using picture ring with multiple controls
I am using a picture ring with 21 pics in it.each pic represent a state, I am using a flat task structure to execute this states. the question is how can I increment the picture ring from inside every single state/task?
regards
Luis
Message 1 of 10
(3,794 Views)
I have written an example for you that demonstrates how to use local variables and property nodes. these two are the easiest way I know how to do it. hope this helps. you may need to place pictures inside the ring. if you don't then enjoy the pics I had in there
Joe.
"NOTHING IS EVER EASY"
Message 2 of 10
(3,794 Views)
Here's a bit more elegant solution. Does not require locals, property nodes, or a sequence structure.
Message 3 of 10
(3,794 Views)
yes you sre right this is a lot more elegant way. I just gave him what he asked for since he was already using a sequence structure. I really like you Idea it is much more efficient and uses less memory.I'm still new to labview but I'm trying.
Thanks for helping me out to dennis everytime I read something of yours I learn something new
Joe.
Message 4 of 10
(3,794 Views)
thanks JHoskins that is exactly what I require
many thanks
Luis
Message 5 of 10
(3,794 Views)
Hi Dennis
I did not explain properly,I need to use the flat task structure for the state machine so JHoskins solution does the job
many thanks for your help
regards
Luis
Message 6 of 10
(3,794 Views)
if you are already using a state machine you should not use a flat sequence structure. you can make your program more useful just by using the state machine itself and telling it which fram to go to when completed I have attached a VI that explains this eaxample
Joe.
Message 7 of 10
(3,794 Views)
Thanks mate,I was wondering how to implement the state machine and this example just did it for me.
two problems solved in one go.
Thank you very much
Luis
Message 8 of 10
(3,794 Views)
E-mail me if you need any further assistance
Joe.
Message 9 of 10
(3,794 Views)
Luis,
Use a local of the picture control. In each sequence, write an increasing
number to the local.
regards,
Wiebe.
"LuisM" wrote in message
news:506500000008000000E2CA0000-1079395200000@exchange.ni.com...
> single state/task?
> regards
> Luis
Message 10 of 10
(3,794 Views)
