using menu in state machine
Hello
I have created a vi which uses a state machine and a cluster of buttons to
swap between various sub-vi's. I am still learning Labview and have recently
come across creating run-time menu's. I would like to be able to implement
menu's in my program such that the user can either use the buttons or the
menu to move to the sub-vi's. i.e. the default case of the state machine
needs to look for both a button press, AND a selection from the menu.
Is this possible?
Jon
(3,986 Views)
If you've played with them, I'm sure you are familiar with 'get menu selection' vi. This vi you have to wire the item tag to a case. Each possible item tag has a case along with one more for no selection or 'default'. In this case put your buttons. So if a menu selection is made, some identifier is passed out of the corrosponding case. If no menu selection is made, the default case is called and the buttons are checked.
Jared
(3,986 Views)
now, why didn't I think of that???! 🙂
That works great - thanks a lot!
Jon.
> checked.
> Jared
(3,986 Views)
I've attached an example (LabVIEW 6) of my favorite state machine architecture. It is based on using queues and handles both buttons and pull-down menus very effectively
(3,986 Views)
Dennis,
Do you have a LV5.1 version of the file you could send me, please?
Russ (rjirberg@aol.com)
(3,986 Views)
Hi Jon,
some time ago I wrote a 'User Interface Template.vi', which was supposed to
demonstrate the use of a state machine for user inputs via
buttons/controls/menus in a tutorial group.
I attach it here (private mail only), but unfortunately it's documentation is a
mixture of English and German. See if it helps ...
Dr Jon Atkinson schrieb:
> Hello
> Is this possible?
> Jon
Dr. Franz Josef Ahlers
Section Semiconductor Devices
Physikalisch-Technische Bundesanstalt
Bundesallee 100
D-38116 Braunschweig
phone: (+49) 531 592 2419
fax: (+49) 531 592 2405
(3,986 Views)
