using global variables
Most reactions were on expected lines the moment  "Global Variables " was mentioned.  This  is akin to  the reactions you get when someone dares to talk about the "GoTo" staement in a "C"  Forum!!  Agreed  each language has some of these  traps.  But  even a trap has a purpose for existence and using it carefully can do no harm.
I saw  the sample code. Yes it is a racy stuff.
Not sure if it will help, but I have tried to bring some discipline into the execution in my attached modified code . Just check it out.
Raghunathan
PS : While on this you may find my other post interesting :http://forums.ni.com/ni/board/message?board.id=170&message.id=129241
Going by the responses I had, there seems little option except to use Globals in THAT particular case and I have been doing it without any problems for the last 2 years or so in machines running 24x7.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
Message 11 of 12
(723 Views)
Hi all...
Thankyou for all of your responses.
I have changed my program as per your suggestions and it works great.
thanks & regards,
radhika venkataraman
Message 12 of 12
(686 Views)
