using global variable VI files in selection
I do not know if anyone try this scheme on labview, but I like to ask you anyway.
Here is my question.
Let say I have multiple .vi files with same set of global variables with different values.
So when I execute the labview program, I will have a option to select one of this .vi global
file, and apply the values I read in from this global file before running my labview application program.
Is this possible thing in Labview?  Do we have any example labview sources?
thank you in advance,
Do
(3,220 Views)
Are you truly talking about global variables as in the LabVIEW structure?  If so, you can't programmatically decide which global variable .vi files to use.
If you want to change what values you use in a program, you'll need to load them from a file where the program can choose which file to load.  Look at the Config File VI's for ideas.
(3,210 Views)
Thank your reply.
As you may guessed, I am not an advanced Labview programmer like you,
so could you provide me with more detail info on how do I look into config VI file?
Do
(3,192 Views)
Look in the Example Finder for Read Configuration Settings File and its counterpart Write Configuration Settings File.
(3,184 Views)
