using error clusters with sequencers
Hi all - as a new comer to LV can anyone suggest the best way to pass the error flow through several frames of a sequencer. I've tried using sequencer locals - but it gets very messy if you need to add a frame. If you create a local from the error in cluster , then is acceptable to convert this from read to write , so that it effectively becomes an error out cluster? and can be read and wrote to in each frame. Or are there other issues?.
thanks dht
(2,964 Views)
Hello dht,
if you can make the dataflow dependent on your error cluster, then you don't need a sequence at all!
See the Labview manual on "dataflow concept".
(2,961 Views)
hi GERDW ,.. thanks for your answer
Yes I agree , but the complexity of test measurements ( Im using the visa libraries and upwards of 30-40 calls to visa vi's) either means several frames of sequencer , or several sub vi's. Since the Sub vi' s would not be particularly re-useable I do not want to take this root. What Im trying to establish is the best way to use visa type read /writes over several frames of sequencer, whilst maintaining the error info flow.
thanks dht
(2,953 Views)
Creating sbuVIs would certainly be a valid way to save diagram space and it seems that's all you're using the sequence structure for. But, if you really don't want to do that, much better than a sequence structure would be a state machine. There are a couple shipping examples that show how you do this but basically, it's a case structure inside a while loop. You have a mechanism such as a queue or enum define the next state to execute. In the case of the enum, inside each case, the next state is wired to a shift register input (right side of diagram). The shift register output (left side) is wired to the case statement's selector input. Things like error connections are also wired to a shift register so that you can pass the value from one state to the next. A state machine has all of the advantages of a sequence structure and not of the drawbacks (and there are many).
(2,945 Views)
