using changing values from velocity to use in an equation
HI, i am a beginner in Lab view and i am trying to program a calorimeter using the following formula
Total Calories Burned = Duration (in minutes) x (MET x 3.5 x weight in kg)/200
what i wanted to ask is how do i use the varying velocity to define what MET number i shud use
TheMET values for running are as follows:
5.5 mph, MET = 18
6 mph      MET = 16
6.5mph    MET = 15
7mph       MET = 14
7.5 mph,   MET = 13.5
8 mph      MET = 12.5
8.5 mph     MET = 11.5
9 mph       MET = 11
10 mph,     MET = 10
11.5 mph    MET = 9
12 mph ,    MET = 8
i have tried case structures and got stuck
your help will be much appreciated
(2,228 Views)
Your use the MET value that correspond to the actual speed. If the speed is varying, create a lookup table and do a linear interpolation, for example.
(I don't understand why you think you need a case structure, except to deal with the situation where the input is out of range.)
What is your raw input data? An array of Speeds at regular time intervals?
(2,201 Views)
