Yes, that's no problem. You can set special values (2,5,7 -> commaseparated), and you can also set ranges (5..10). You can also set open ranges (10..) which means all values >= 10.
Thomas
Using LV8.0 -------------------------------------------------------------------- Don't be afraid to rate a good answer... 😉 --------------------------------------------------------------------
