using Port32 input in runtime environment
When I created a Build from my project and run it in a runtime environment instaed of the development evirnment the Port32 input cannot access to the cviVXDWrapper.dll
The runtime and the development system is the same computer with WinXP and LabView 8.0
How do I have to set the build specifications?
Patrik
Message Edited by paddy0002 on 02-20-2008 09:43 AM
(2,775 Views)
Accepted by topic author paddy0002
Hi paddy0002,
the Out-Port VI uses the cviVXDWrapper.dll, so normally you will get this error message if the dll can't be found. Have you installed the CVI runtime-engine?
Bernd
(2,748 Views)
