Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
using MoveBlock for an array of two dimensions
People,
I've seen this example, http://zone.ni.com/devzone/cda/epd/p/id/3672 and would like to adapt it to a array 2-D.
My C code is something as:
int **ReturnIntPointer(void) {
    int **array;
    (initializing and malloc the array)
    return *array;
And in the VI, the parameters configured in the Call Library Node for MoveBlock are the same? (obviously changing the dimension to two dimension).
For the size, is not a matter of simply multiply to the existing VI the number of dimensions (two)?
Message 1 of 1
(2,596 Views)
