using DAQCard 700 with LABView evaluation
Thanks to all of you who responded promply with great information to my previous posts. Here's another...
I'm having problems interfacing my DAQCard 700 with LABView. It's probably as plain and fundamental as it gets...I just can't get LABView to recognize the hardware. Even when I configured the card as device 1, when I use the get daq info function, I get AT-MIO-16E-2. All I need is to output a digital signal to one pin. When I use the example simple digital I/O VI's to test the card, the input tracks the output even when there's no jumper between the pins! How can I find out what values to put in for digital channel and line? I tried both the pin numbers and names from the DAQCard manual but they didn't seem to wo
rk.
I would greatly appreciate any advice anyone could offer.
(2,501 Views)
Hello;
That is probably an installation problem. When installing the evaluation version of LV, you need to specify that you will be using a real hardware as oppose to a simulated one.
Hope this helps.
Filipe A.
(2,501 Views)
