before some weeks i ask the same question and after that i become some good questions, but i can't find a answer for my problem. Maybe now i describe it more and i attached my Programm, where you can see my problem.
At first, i use Labview 5.1 and i can't open Labview 6.x VI's, so please if you attach a programm so save it as LV5.1 thank you.
My ActiveX funktions very good and i don't have problems with it, bevause i use in the programm (SUBCI EXCEL) to read some numbers from a Excel File who works with ActiveX.
In the Programm you can see the variables "Helligkeit" ->x, "Luftfeuchtigkeit"->y and "Stellwert"->z
If x or y changes, i have another value for z, and i will show it in the 3d graph li
ke the screenshot waver.jpg i attached.
The problem is, when i change x and y or keep it constant, it doesn't matter i can't see any draw in the 3D Surface.
Do i need 3D Parametric Chart or 3D Curve Graph.
The result is important, so if you have a idea so please attach a picture or change the VI and save it as LV5.1.
There are some SubVI's but if you understand my problem, then you don't need this SUBVI's. You can also make a new LV5.1 VI only to show me how this 3d Curve Graph or 3D Surface works.
So you can't imagine how much i thank you if you help me.
Thanks for your answer in advance!It's very important please help me!Maybe you can earn some money if you help me more, info per email(NO JOKE)!
Greetings,
Ender Ekinci
P.S.: You can send me a Email if you have agood idea or do you know to solve this problem
ender.ekinci@epost.de
