using 2 analog inputs on usb6251 simultaneously
hello,
Is it possible to use 2 analog inputs of usb6251 simultaneously? I want to use 2 AI at same time and show the output.
But i am not quiet sure. Any suggestions are appreciated.
(2,581 Views)
Accepted by topic author Radhika_Nimbalkar
Hi Radhika,
Yes, that's possible.
You just need to put two channels into the AI DAQmx task and switch the DAQmxRead function to "n channels…"!
(2,577 Views)
Thank you.
Yes that way is great option.I want to know one more thing. How can i show  2 AI output in different graphs? Is it possible to get two different graph for 2 AI and show output at same time?
(2,558 Views)
Hi Radhika,
So you have an array of elements and you want to show the elements using separate indicators?
Then you need to index the elements and wire them to their indicators!
(This is basic LabVIEW stuff: you just need the IndexArray function!)
(2,546 Views)
I am measuring 2 analog signals one is amplified signal and one is without amplification. I want to check both signal same time and show result of both signals simultaneously on different graphs.I am going to use the solution you suggested but unable to understand that how to take two outputs from daqmx read?
(2,540 Views)
Hi Radhika,
As said before:
  1. configure the task to contain 2 channels
  2. configure DAQmxRead to "n channels" mode to read samples for all channels in the task
What have you tried and where are you stuck?
Did you opened any examples from example finder to learn DAQmx basics?
(2,516 Views)
Thank you for help.
Yes I read DAQmx basics and tried your suggestion. I will test it on hardware once I finish my hardware setup and see if I get expected result.
Thank you again for your time.
(2,512 Views)
